Soundswitch USB-->DMX
  • VJ Hieros Gamos
    by VJ Hieros Gamos » Thu Feb 11, 2021 2:57 am
    Hello, everyone !
    I've bought a USB/DMX from SoundSwitch, and I wanted to know how I can use it with madmapper ? Can I use the two universes ?
    Thanks a lot,
    Jay.
    Re: Soundswitch USB-->DMX
    by mad-matt » Thu Feb 11, 2021 3:01 pm
    No, MadMapper only supports garageCube USB DMX, Enttec Pro & Enttec Mk2. We prefer not to support everything but focus on reliability. Handling many hardware would require more work to keep them perfectly stable on macOS & Windows, & update the code when hardware is changed etc.
    garageCube USB DMX is nice because it has double buffering, so sending a black & white strob to RGB LEDs, you sure you'll never get some colors appearing (wihch happens with others, it is sending DMX universe data while it updates the data from an incoming USB packet, so you'll get part of the universe from a MadMapper frame and the rest from the next MadMapper frame... that can be very annoying)
