The projector moved. Can you adjust it with MiniMad?
  • AgentD
    by AgentD » Tue Mar 09, 2021 7:02 pm
    I made a permanent projection installation recently with MiniMad but the projector was slightly moved. Due to that the projection is mismatched with the surface and it needs to be adjusted. It's very difficult to access the projector therefore I am hoping that there is a way to shift the entire projection from MiniMad. Can you use the onboard buttons to do that? The mapped surface has many quads and masks so I would like to simply shift the entire image at once. Please advise. Thank you!
    Re: The projector moved. Can you adjust it with MiniMad?
    by MADben » Wed Mar 10, 2021 1:32 pm
    you can use the buttons indeed, press the red one to activate mapping mode (more details in the minimad guide)
    otherwise, you'd need a computer and MadMapper in order to shift the entire projection
  • AgentD
    by AgentD » Thu Mar 11, 2021 6:50 am
    Thank you
    by Pierre Guilluy » Thu Mar 11, 2021 12:52 pm
    A precision: using MiniMad's buttons (or USB computer-keyboard), you can either adjust each individual surfaces, or move all surfaces at once by pressing YELLOW (previous control point) right after entering mapping control mode by pressing RED.
