MadMapper 4.0.10 available
    by MADben » Fri Apr 09, 2021 5:36 pm
    Dear Mappers,
    We released two new versions (3.7.11 and 4.0.10), mostly fixing an issue with macOS 11.3, a
    The update are available on Yourspace as usual -> https://madmapper.com/yourspace/
    MM 4.0.10 Release Notes
    FIXES
    - Fixed possible issue with drag & drop from Finder on macOS 11.3
    - Fixed possible issue in DMX Monitor
    - When duplicating / cloning multiple surfaces / fixtures, preserve source order
    MM 4.0.9 Release Notes
    ADDITIONS
    + Added new Guides in Help menu
    + Added seeeduino support in ArtNet to USB LED (Arduino)
    + Added “replace file” option for ISFs
    FIXES
    - Fixed possible issues with external GPU on macOS
    - Fixed possible startup issue on Windows depending on system locale
    - Fixed issue on macOS when main window is maximized and we enable syphon on a projector
    - Fixed issue when pasting a cue (inserting useless columns)
    the MAD Team.
