MadMapper 4.1 BETA available
    by MADben » Tue Apr 27, 2021 3:36 pm
    Dear mappers,
    The MadMapper 4.1 BETA version is now available on Yourspace!
    We're excited to introduce new additions, all made with love and madness...!
    First, there is a redesigned material library which now integrates...Surfaces FX!
    This is a feature that some of you have been waiting for a long time : you can now design, code and share your owns to the community!
    You can now also try the Firmata module allowing you to communicate with your Arduino devices in a super easy MadMapper fashion style!
    The new Weather and Pollution modules allow you to connect to meteorological data in order to incorporate them in your mapping projects (more info in the dedicated guide available in the Help Menu or Yourspace)
    We also added a Shutdown OSC command for Video, Light and MiniMad controller as well as manual network configuration for both Video and Light mapping!
    Download the BETA on https://madmapper.com/yourspace/
    Plus, your feedback is always valuable to us!
    If you have a bug to report or if you want to share feedback, feel free to write to userfeedback@garagecube.com
    Don't forget that this is a BETA version, so use at your own risk if you're in production!
    4.1.0 BETA Full Release Note
    ADDITIONS
    + Online library for Surfaces FX (2D, 3D, Lines)
    + Surfaces FX are now editable in code editor and can be published online as materials
    + Firmata Module: simply communicate with your Arduino (in & out)
    + Weather and Pollution Modules (drive your MadMapper from online weather / pollution data)
    + Controls Combiner Module (ie drive a parameter with a MIDI fader and a MIDI button with various combiations)
    + MiniMad: Added manual network configuration for Video & Light
    + MiniMad: Added shutdown OSC command in Video, Light and MiniMad Controller
    + MiniMad: New unified TouchOSC layout with shutdown function (available on MadMapper Yourspace)
    + New resource selector (materials, generators, surface FX, modules)
    IMPROVEMENTS
    * Improved Surface3D shadow quality
    * Resource Library grid view with thumbnails
    * Materials: handle mipmapping in IMPORTED images and INPUTS of type image
    * MadLight Recorder settings are now saved in project
    * MiniMad Light settings are now saved in project
    * MiniMad Light now fades DMX and audio while shutting down
    * MiniMad Video now fades video and audio while shutting down
    * Updated MiniMad user-guide
    * Improved Code Editor
    * Canon Cameras appears as a media in MM, with a button to take a new picture
    FIXES
    - Fixed possible issues with eGPU on macOS (in this situation use the dedicated build on Yourspace)
    (a MadMapper 4 license is required to use this BETA version)
    We hope you will love it!
    Enjoy!
    The MAD Team.
  • jasonbeyers
    Re: MadMapper 4.1 BETA available
    by jasonbeyers » Sat May 08, 2021 9:21 pm
    THANK YOU! This is amazing. This surface (and line) FX support makes Madmapper an even more powerful creative tool! The ability to share FX shaders with others is also wonderful :D
    The new library view options and the new multi-input control module are great as well!
    by MADben » Fri May 14, 2021 11:41 am
    the BETA 2 is now available on Yourspace..!
