Remote Licencse Rests - upgrade
  • howie_b
    by howie_b » Fri Jun 11, 2021 1:11 pm
    Hi
    Just wondering if i upgrade to v4 - if the number of remote liecence resets gets reset.
    It would be handy to use one reset now, especially as i'm about to upgrade and hope it might come with a new reset.
    Thanks
    Re: Remote Licencse Rests - upgrade
    by MADben » Mon Jun 21, 2021 9:28 am
    Updates and upgrades do not affect the number of resets available on Yourspace.
    On the other hand, if you need a reset and you don't have any in Yourspace, contact the support via support@garagecube.com for help
