MadMapper 4.1 Released
    by MADben » Tue Jun 15, 2021 5:02 pm
    Dears mappers,
    After a couple of Beta versions, the 4.1.0 update is now available on https://madmapper.com/yourspace/
    It introduces the Firmata, Weather and Pollutions modules, a shutdown OSC command and manual network configuration for the MiniMad, the render to texture option for materials, a redesigned material library and of course... Surfaces FX !
    Which means you now design and share your own FXs !
    M 4.1.0 Release Notes
    ADDITIONS
    + Online library for Surface FX (2D, 3D, Lines)
    + Surface FX are now editable in code editor and can be published online as materials
    + Firmata Module: simply communicate with your Arduino (in & out)
    + Weather and Pollution Modules (drive your MadMapper from online weather / pollution data)
    + Controls Combiner Module (ie drive a parameter with a MIDI fader and a MIDI button with various combiations)
    + MiniMad: Added manual network configuration for Video & Light
    + MiniMad: Added shutdown OSC command in Video, Light and MiniMad Controller
    + MiniMad: New unified TouchOSC layout with shutdown function (available on MadMapper Yourspace)
    + New resource selector (materials, generators, surface FX, modules)
    + Materials can be optionally rendered to a texture
    IMPROVEMENTS
    * Improved Surface3D shadow quality
    * Resource Library grid view with thumbnails
    * Materials: handle mipmapping in IMPORTED images and INPUTS of type image
    * MadLight Recorder settings are now saved in project
    * MiniMad Light settings are now saved in project
    * MiniMad Light now fades DMX and audio while shutting down
    * MiniMad Video now fades video and audio while shutting down
    * Updated MiniMad user-guide
    * Improved Code Editor
    * Canon Cameras appears as a media in MM, with a button to take a new picture
    * Improved Cue Bank Live mode (show transition time & last executed cue)
    * 2D coordinate widget: we can now double click X / Y field to enter a value manually
    FIXES
    - Fixed possible issues with eGPU on macOS (in this situation use the dedicated build on yourspace)
    - Fixed possible issue with drag & drop from Finder on macOS 11.3
    - Fixed /cues/active_bank Control
    - Fixed DMX recoder FPS issue when recording external output
    - Fixed rendering surfaces in syphon / spout loopback in some cases
    The update is free for all MadMapper 4 owners.
    We hope you'll love it!
    The MAD Team.
  • balamsoto
    Re: MadMapper 4.1.0 Released
    by balamsoto » Wed Jun 23, 2021 6:27 pm
    Great News.
    some questions
    where is the weather / pollution module
    same for minimad manual network configuruation and shutdown osc command
    by franz » Thu Jun 24, 2021 10:05 am
    modules are in the module panel, on the left.
    There's a Weather/Pollution module guide in the /Help section.
    by MADben » Fri Jun 25, 2021 11:38 am
    the manual network configuration for MiniMad is available during export + check the touchOSC layout on Yourspace, you'll get a proper Shutdown tool
    otherwise, the OSC commands :
    /shutdown + int OSC value: value = 1 will trigger the MiniMad shutdown which will be effective after 2,5 seconds, unless cancelled by a value = 0
    /shutdown/all + int OSC value: identical to /shutdown except it applies for all MiniMad units in the same group
Users browsing this forum: No registered users and 57 guests
