Constant stutter on output
  • klif
    by klif » Mon Jul 05, 2021 3:53 pm
    This is probably not an issue with Madmapper, but something that happens later in chain.
    I have a PC (win 10), MadMapper 3.7.8 , with NVIDIA GeForce Titan X 12GB, going to three Datapaths FX4. Each Datapath is connected to three projectors. So far, so good.
    The issue is constant stuttering happening at the output. It happens aproximately once a second, in steady rhythm. I know it is not related to the video I made, because the same stutter happens also if I play built in Madmapper materials. It is most visible with horizontal scrolls, and absolutely terrible with a certain speeds of zoom.
    I tried changing display settings, but there is not much I can do. Apparently Datapath only allows 30Hz over HDMI lines, and that is what I can get in Windows system settings.
    Any help is appreciated.
    Ivan
    Re: Constant stutter on output
    by franz » Tue Jul 06, 2021 10:46 am
    0. make sure you've got the latest nvidia studio driver (not game ready)
    1. does the stutter happens with only one output monitor connected (no datapath) ?
    2. does the stutter happens with only 1 datapath ?
    3. in madmapper /preferences / engine, are you in directx or opengl ?
    directx should be preferred.
    4. in madmapper / preferences / engine,
    - check "use maximum priority"
    - uncheck "use double buffering for previews"
    5. if your video files are @30 fps and your datapaths are @30Hz,
    then in madmapper / preferences / engine, set your framerate to 30 instead of "Auto"
    6. report back here so that it helps other users as well.
