Multiple audio channels in for modulation
  • kristofferlislegaard
    by kristofferlislegaard » Wed Jul 07, 2021 12:08 pm
    It is really great to use audio as a modulation source. It is quick and easy to configure. But I have a lot of inputs on my audio interface, it would be great to be able to use more than one as a modulation source. Say channel 1 for opacity on layer 1 cue 1, channel 2 for something else, channel 3 etc.
    Would make it much easier to make audiovisual performances with multiple computers work since audio is so fast. I tested and for me it makes more sense to use audio than osc to control some stuff that should be super snappy.
    Hoping this is something that could easily be implementet.
    Re: Multiple audio channels in for modulation
    by franz » Mon Jul 19, 2021 12:03 pm
    go to madmapper/prefrerences/audio and select the audio channels of your soundcard you want to use for modulation.
    by kristofferlislegaard » Tue Jul 20, 2021 8:21 pm
    How do I select more than 1 (or channel 1 +2 summed together) channel?
    I want to have f.ex. 8 audio channels inn to modulate different things.
    by mad-matt » Wed Jul 21, 2021 11:08 am
    When you add an audio control in MadMapper, you can choose the audio input channel to use, see screenshot
    Screenshot 2021-07-21 at 11.07.34.png (127.6 KiB) Viewed 3950 times
    by kristofferlislegaard » Thu Jul 22, 2021 12:37 pm
    FANTASTIC! Thanks a lot Franz and Mad-matt !
