free frame colorwarp problem
    deepvisual
    by deepvisual » Mon Jun 02, 2008 9:22 pm
    I can't get the colorwarp plug in to work in modul8
    tried jpegs and .movs
    the screen just goes blank.
    any ideas???
    using a G4 powerbook and a MBP
  • maxus
    by maxus » Tue Jun 03, 2008 11:51 am
    same problem here :) but try the hue cycle which you can achieve the same effect
    david
    by david » Thu Jun 05, 2008 12:57 pm
    I do not manage to reproduce the problem on my Mac Pro with nVidia cards and Modul8 2.5.5 beta.
    Freeframe Colorwarp is working OK on my machine.
    What is your configuration :
    - OS : Tiger, Leopard, which version ?
    - Video config : one output, 2 or more ?
    - video cards in your machine ?
    Best regards.
  • maxus
    by maxus » Fri Jun 06, 2008 12:19 pm
    macbook pro 2,4ghz
    leopard 10,5,3
    http://www.apple.com/macbookpro/
    no output or one output... doesn't matter
    deepvisual
    by deepvisual » Tue Jun 17, 2008 7:41 pm
    I have two machines.
    a MBP and a G4
    both have the same problem.
    I guess it is a software conflict as one is a clone of the other.
