content not playing through mask
  • ladyk_coding
    by ladyk_coding » Sat Jul 31, 2021 6:04 am
    I'm running a Processing sketch through Madmapper (4.1.0) using Syphon. I've got several masks in one quad with the content playing across the inverted masks. I'm not sure how it happens, but I find myself in a predicament where the content stops playing through one of the masks and I can't quite figure out how to get it going again. I sense it happens after I tweak the mask.
    Screen Shot 2021-07-30 at 11.43.38 PM.png (766.76 KiB) Viewed 3770 times
    It's Mask 1. The masks are inverted.
    I've played with the layering order. I've clicked the media and applied it to selections. I've re-started Madmapper. None of that rectifies the situation. I imagine it's something straightforward that I'm missing.
    Any insight is appreciated.
    thank you kindly in advance for your time,
    LadyK
    Mac Mini 10.13.6
    Re: content not playing through mask
    by mad-matt » Wed Aug 04, 2021 12:21 pm
    Which version of MadMapper is it ?
    Could you send the project file ?
  • ladyk_coding
    by ladyk_coding » Fri Aug 06, 2021 6:18 pm
    Madmapper version 4.1.0.
    This happened to me in previous versions as well, so I figure it's something in the work flow/process on my end.
    The forum via Chrome (92.0.4515.107) would not allow a .map file to be attached. As such, here's a link to the project file ---> https://drive.google.com/file/d/1FsOCEa ... sp=sharing
    I'd be grateful for any insight, etc.
    thank you kindly for your time,
    LadyK
  • ladyk_coding
    by ladyk_coding » Tue Aug 17, 2021 8:59 pm
    Any chance anyone has some thoughts on this? I imagine it's something quite simple and straight forward. Yet, it seems to happen to me every so often, despite repeating the same steps (as far as I can tell).
    I do understand the people are busy, or perhaps lucky to be on vacation. Still, deadlines are closing in for the rest of of us.
    I'd be grateful for a few minutes of someone's time and insight.
    Thank you kindly,
    LadyK
    by MADben » Wed Aug 18, 2021 4:54 pm
    Matthieu, the one able to investigate your issue isn't available at the moment,
    He'll surely get back to you as soon as he can though
