best hardware setupt for 5 outputs forfix installation
  • simonhu
    by simonhu » Wed Aug 18, 2021 10:30 am
    Hello
    We have an upcoming installation for total 5 projectors with WUXGA resolution per output.
    What is the best hardware setup for a fix installation with 24/7 running time.
    Our preferred machine
    Win10 LTSC
    I7 CPU i7-10700K
    GPU 2x RTX 4000
    Blackmagic Design DeckLink Mini Recorder 4K
    nVidia Quadro Sync II
    We need to make sure that the output destinations refers always to the same projector (EDID). GPU1 has 3 projectors for room 1 and GPU2 has 2 projectors for room 2.
    We want to use an external HDMi source for 1 Quad in Madmapper. Therefore we need the Blackmagic Input Card.
    Any other advices or maybe better configuration?
    Thank you
    Re: best hardware setupt for 5 outputs forfix installation
    by mad-matt » Thu Sep 02, 2021 6:28 pm
    That should be perfect. MadMapper uses EDID when available on Windows. So swapping the cables or rebooting windows should affect where MadMapper will output which content.
    Some identical screens will give the same EDID serial, but a good video projector should not. If it's the case, a cheap EDID manager would solve, ie: https://www.amazon.com/Zerone-Feeader-M ... ics&sr=1-5
  • tontechnik
    by tontechnik » Mon Sep 13, 2021 10:42 am
    So Multi-GPU is now possible with MM??? :shock: That seems to be new to me...
Users browsing this forum: No registered users and 60 guests
