Reordering of groups/surfaces
  • Vibber
    by Vibber » Thu Aug 19, 2021 4:11 pm
    Hi there, I have a project with a bunch of groups with surfaces in them and I want to move some of the groups to get them in order. First they are like this
    group 2
    group 1
    group 3
    What I want is
    group 1
    group 2
    group 3
    However when I want to place group 2 I always get
    group 1
    group2 (it's inside group 1)
    group3
    Imagine I have 30 or more groups to reorder. How do I achieve the order I want?
    Re: Reordering of groups/surfaces
    by mad-matt » Thu Sep 02, 2021 6:12 pm
    You have to look at the white line when dragging. If it starts for the extreme left, it means it will not be moved inside a group.
    If you drag over a group item or one of its child, it will propose to insert the dragged group inside this group, but if you drag bellow the group it will propose to move it below the group (and not inside), it's a matter of pixels but the white line says what will happen.
    Let me know if it's not clear.
