Teensy - LED's remain on white
  • lumatribe
    by lumatribe » Thu Sep 09, 2021 5:12 pm
    Hello!
    My FastLED test works no problem. The file from Madmapper's yourspace "serial-only-single-line" also works but when I send it to Teensy, all LED's are a mid-brightness white. Then as soon as madmapper is launched, they all go full bright white. I can see the shaders working on top of the already fully lit LED's. I feel like when I transfer the serial only single line to teensy, all the LED's should be off. Then the shaders in MM should work fine. If I bring the luminosity down, the shader disappears and the LED's remain bright white.
    I am using Teensy 4.0 and WS2812B Led's and the latest version of madmapper.
    Any help would be greatly appreciated. It's been 2 weeks and I feel defeated. I would pay for patreon help as well.
    Thank you!!!!
