Is it possible?
  • IHS2021
    Is it possible?
    by IHS2021 » Fri Sep 17, 2021 4:32 pm
    I'm working on an interactive, that involves projecting from a source from a web URL. Is it possible to use madmapper to project a source from online? What i'm hoping to do, is crop a section of the screen using mad mapper, so the projector only projects what I'd like to show. Is this something I can accomplish? I can provide more details if needed.
    Re: Is it possible?
    by franz » Mon Sep 20, 2021 1:23 pm
    I'm sure there's a syphon tool that can capture web and send it to madmapper
    Re: Is it possible?
    by mad-matt » Mon Sep 20, 2021 1:57 pm
    On Windows, vMix is able to capture each tab of your browser and stream it to NDI (or something like that). On macOS I suppose NDI screen / browser capture is possible.
    For Syphon (macOS) I suppose the good one is https://macdownload.informer.com/screencapturesyphon/
    But I also see this project (I have not tested): https://github.com/glowbox/ChromeSyphon
  • IHS2021
    Re: Is it possible?
    by IHS2021 » Mon Sep 20, 2021 4:26 pm
    Great, thank you so much. I hate to ask, but what is "NDI" ? So basically using a screen capture software, I could potentially import into MadMapper. Do you happen to know of any documentation on using a screen syphon or screen capture with madmapper? I've only briefly used the software and i'm still learning it. Thanks again for your responses, I really appreciate it.
    Re: Is it possible?
    by Pierre Guilluy » Wed Sep 22, 2021 4:44 pm
    https://en.wikipedia.org/wiki/Network_Device_Interface
    It allows for video streaming between a sender and a receiver with minimal latency and maximum quality.
    MadMapper can both send and receive NDI.
Users browsing this forum: Baidu [Spider] and 74 guests
