Scene thumbnails - feature request
  • Simon_Holden
    by Simon_Holden » Sat Sep 18, 2021 7:29 am
    Would love to have a feature where you can capture the current output for a thumbnail for a scene. Often this is a combination of a few media outputs. My current workflow is to use snipping tool and grab a snip of the current output, save it to file, click on the cog on the scene, click use image, select the image.
    Would be amazing if you can just say, sample current projected output... or something like that...
    Re: Scene thumbnails - feature request
    by mad-matt » Mon Sep 20, 2021 1:59 pm
    On macOS, I use the Cmd+SHIFT+4 key combination to capture a rectangle of the screen, then drag&drop the screenshot on the scene cell, it takes 3 minutes and allow you to choose the part of the preview to capture (usefull if you have multiple projectors, or dmx fixtrures). Of course for a simple project with a single video projector, automating that would make sense.
