Issue with OSC Out
  • Simon_Holden
    Issue with OSC Out
    by Simon_Holden » Sat Sep 18, 2021 9:34 am
    I'm trying to trigger some OSC commands from Madmapper to some other software. I've created an OSC out, and I can recieve OSC no problem on my other software if I manually click Send Now, or if I enable Send On Velue Change and change the integer value, but I am not getting the values when I trigger the send on a Cue.
    Hope I can get this working so I can send some feedback to my custom gui from what cue is active in mad mapper.
    Thanks you!
    OSC Send on Cue.PNG (68.64 KiB) Viewed 2418 times
    Re: Issue with OSC Out
    by mad-matt » Mon Sep 20, 2021 1:54 pm
    We solved that for MadMapper 4.2 beta 2, or maybe directly in final release. Thanks for reporting and sorry about this issue !
    Matthieu
  • Simon_Holden
    by Simon_Holden » Sun Sep 26, 2021 7:56 am
    Amazing work, thank you!
