Publish to NDI hides mouse on OSX 11.6
  • al_baum
    by al_baum » Wed Sep 22, 2021 11:07 am
    Before I contact support. Is anyone else experiencing this behaviour ?
    Open new project. Go to Projector . Select 'Publish to NDI'. When hovering the mouse over the screen, the cursor disappears in the bottom right corner.
    I am on a Macbook pro with touchbar. Osx 11.6, and madmapper 4.1.1.
    here is a screenshot if you want to see what I mean.
    https://www.dropbox.com/s/xnlcd87phcc8l ... ..mov?dl=0
    Thanks
    Best
    Alain
    Re: Publish to NDI hides mouse on OSX 11.6
    by mad-matt » Wed Sep 22, 2021 11:24 pm
    Please re-download MadMapper 4.1.1 from yourspace and confirm this has been solved.
  • al_baum
    by al_baum » Fri Sep 24, 2021 1:09 pm
    Hi Mathieu,
    Thank you for the reply. I redownloaded MM 4.1.1. but the problem is still there.
    I downloaded MM 4.2 Beta1 as you suggest in other thread and confirm that in this version the problem disappeared.
    Best
    Alain
  • al_baum
    by al_baum » Sat Sep 25, 2021 9:10 am
    Hi again,
    SInce I am now using MM 4.2 Beta 1: is there a time limit for tis beta version ? I do not see any mention of it on the splash screen, but I remember other beta version were limited in a time period.
    Thanks
    by MADben » Mon Sep 27, 2021 2:04 pm
    the Beta expiration date is October 29th
    But actually the proper 4.2 release may be released this week or the week after
