MadMapper 4.2 available
    by MADben » Thu Sep 30, 2021 11:22 am
    Dear mappers,
    It was time for a big MiniMad update!
    This new 4.2 version brings much needed features that will greatly improve the productivity of MadMapper's best companion...!
    -> Remote Export
    No more need to take the SD card out of the MiniMad and go back to the computer to export: being on the same network, you can now export remotely!
    The option appears in the export window: insert a MiniMad SD-card or select a remote MiniMad in the drop-down list
    -> Default Settings
    The MiniMad offers advanced export settings that have been greatly improved since MadMapper 4,
    But it often happens that you change several settings until you don't remember what the original ones were,
    If the physical result does not suit you anymore for example, redo an export and click on Load default setting
    -> Smart Updating
    After modifications you only need to update the mapping of your project for the MiniMad? Or you only need to update the media?
    It's now possible: no need to re-export the whole project, choose to update either everything, the mapping or the media
    * A MadMapper 4 license is required to used this new update available on https://madmapper.com/yourspace/
    4.2.0 Full Release Note
    ADDITIONS
    + MiniMad Export: Added remote-export to export your show though the network
    + MiniMad Export: Added default settings loading
    + MiniMad Video: Added the possibility to update the mapping or the media separately
    + MiniMad Controller: added up, down, left, right mapping buttons for precise adjustments
    + MiniMad Controller: make all mapping and image controls mappable
    + Controls can now be ordered by internal drag
    IMPROVEMENTS
    * MadLight Recorder: Improved support for very large sequences
    * MiniMad Light: Boosted the default analog audio-jack output level
    * MiniMad Light Export: Better export progress
    * Better handle video-inputs reconnection
    * Handle camera disconnection / reconnection on Windows
    FIXES
    - MadLight Recorder: Fixed newly recorded sequence not being checked and selected
    - MiniMad Export: Fixed MiniMad SD-card not loading in rare situation (Mac)
    - MiniMad Video: Fixed exporting surfaces with mesh-warping and lots of control points
    - MiniMad Video Export: Fixed possible issue with default output frequency
    - MiniMad Controller: Fixed possible issue with shutdown function
    - Fixed a problem with audio playback of movies using AVFoundation (Mac)
    - Fixed possible problem in Weather module
    - Fixed possible problem in Firmata module
    - Fixed an issue with Firmata on Windows
    - Fixed a problem with material thumbnail generation
    - Fixed problems in cue edition
    - Fixed output cursor when projector is flipped
    - Fixed sACN network interface not being saved correctly
    - Fixed sACN Input network interface selection in preferences
    - Fixed possible issue with PS3/4 Controls after reloading a project
    - Fixed Output Cursor when video projector is flipped
    - Fixed possible issue cueing multiple FX on the same surface
    - Fixed possible issue with AVFoundation movie player audio playback
    - Fixed a problem in Weather module
    - Fixed cueing Osc Output "Send Now" button
    - Fixed specific blending modes (Multiply-Stencil Luma...) on lines (broken since 4.1)
    - Fixed PS3/4 controls after reloading project if gamepad is connected on a different port
    Enjoy !
    The MAD Team.
  • LEGZA84
    Re: MadMapper 4.2 available
    by LEGZA84 » Thu Sep 30, 2021 11:53 am
    Great news!!!
    Btw, still not possible to work with .obj and MiniMad...?
    Thx
    by franz » Tue Oct 26, 2021 11:26 am
    not possible, as we never really thought of it ...
    added to our todo list
