Interactive Wall
  • trillius
    Interactive Wall
    by trillius » Thu Sep 30, 2021 11:56 am
    I would like to make an installation like that of the youtube link.
    https://www.youtube.com/watch?v=BGraNTGqAxQ
    I was thinking of using MadMapper by interfacing it with a sensor projector, such as those used for teaching whiteboards.
    The wall will have about 10 sensitive areas that if touched by the user start animations.
    Is it possible to do it with MadMapper?
    Do you have any advice on the type of projector and sensor?
    Thanks in advance
    Re: Interactive Wall
    by franz » Thu Oct 14, 2021 3:43 pm
    as long as these areas send information to madmapper, either in midi format or osc, you're good to go.
