SCENE FADE OUT
  • digginmap
    SCENE FADE OUT
    by digginmap » Wed Oct 06, 2021 3:20 pm
    Hi everyone,im new in the forum also first attempts with MadMapper. So im workin into a show with couple of easy projections on the stage. Im not sure if im doing it right, anyway im working with 9 scenes + 9 black scenes so the thing is like Black1 Scene 1 Black 2 Scene 2 etc. So my problem is that when switching to the black scenes the fade out starts from the first frame of the previous scene. so i would like to make the scene fade away from the last frame. is there a way to do this? also forgive my poor english. have a great day
    Re: SCENE FADE OUT
    by franz » Thu Oct 14, 2021 3:46 pm
    sounds like a bug. we'll check that.
    Re: SCENE FADE OUT
    by mad-matt » Fri Oct 15, 2021 9:26 am
    By default, start a scene will restart all medias. This is desired in many cases. But in your situation, you can disable the "auto-restart" of all movies in blackout scenes. To do so, select a blackout scene, open cue "inspector" (button on the right of cue bank tool bar), type "restart" in the search box, select all item in list (Cmd/Ctrl+A), and uncheck the value checkbox (you can also do it once for all blackout scenes by sellecting all scenes)
