Save sequences as part of Madmapper save file
  • Simon_Holden
    by Simon_Holden » Tue Oct 12, 2021 6:53 am
    If you create a number of light sequences, together with audio, (for example I have 10 samples, and 10 light sequences set up for export), I'd like to save this as a setup, my work around at the moment but to do this is to zip up the sequence files and store separately, and unzip into the madlight sequence folder to recall these at a later date. It would be great if these automatically get pulled out of the project, IE, the sequences don't even show up unless you load a project that had those sequences as part of it.
