Midimad Light not saving playback mode
  • Simon_Holden
    by Simon_Holden » Tue Oct 12, 2021 8:47 am
    Setting the playback mode in the export to MadLight Serquences to Minimad dialogue doesn't export properly.
    Seems to be different every time, I have the minimad attached to a screen so I can check this, and it's almost always different from what you set it to once you've power cycled the unit.
    Re: Midimad Light not saving playback mode
    by Pierre Guilluy » Fri Oct 22, 2021 9:49 am
    Ok, so the export is not necessarily the problem but you witnessed the MiniMad using a different playback mode when it's restarted, is that correct?
