QUESTION FOR BCR2000 USERS
  • vjdickhead
    by vjdickhead » Thu Jun 05, 2008 6:46 pm
    Hey there everybody
    I have a question for all those people who use the bcr2000
    I'm trying to get the bottom right collection of buttons to work as non latching. (the four single buttons in the bottom right of the controller.
    by default they are latching, and i can easily change that but my problem is when i switch presets and back again the buttons switch back to default latching. I need to use them for bpm control, ie tap tempo etc. It's like they're not saving, but i'm doing as the manual says to store and the other 16 buttons across the top work perfectly as i wish using the same storing method..
    I suppose i can free up one of the top 16 but i would have the perfect mapping for my sets if i could just get these damn buttons non latching.
    any help or advice is so warmly received.
    cheers guys
  • vjdickhead
    by vjdickhead » Thu Jun 05, 2008 10:00 pm
    stupid of me, figured it out eventually after pulling my hair out.
    It was temp storing the data, i was pressing store while still in edit mode. you have to save the preset by hitting store once you have exited edit mode.
    false alarm.
    cheers anyway
