Problem Blackmagic intensity 4K and madmapper 4
    Tartare
    by Tartare » Wed Oct 27, 2021 9:10 pm
    Hello everyone,
    I have a problem since version 4 of madmapper with my blackmagic intensity acquisition card.
    She no longer recognizes what goes into HDMI. I tried on WINDOWS and MACOS without success.
    However, it works with version 3.7.11 on both systems.
    I tried the different options of the preference panel.
    The solution that I found is to open the two versions 3.7 and 4 and make a bridge by SYPHON or SPOUT but it is not very practical ...
    Do you have any suggestions ?
    Thanks to the garagecube team for version 4 which apart from this problem is a great upgrade !!!
    noirtartare.fr
    garexp.org
    Re: Problem Blackmagic intensity 4K and madmapper 4
    by mad-matt » Thu Oct 28, 2021 11:18 am
    Is you installed version of blackmagic desktop video up to date ?
    Tartare
    by Tartare » Sat Oct 30, 2021 12:08 pm
    Hi Matt,
    Yes i have the latest version of desktop video (on the PC).
    first configuration is : PC, core i7, 16gb,geforce gtx 96O, windows 10, PCI intensity 4K, desktop video 12.2
    second configuration : MacPro 5.1, 16gb, ATi 750, MacOS 10.11, PCI intensity 4K, desktop video 10.9.5
    Madmapper 4.2 on both configuration.
    noirtartare.fr
    garexp.org
    Tartare
    by Tartare » Fri Nov 12, 2021 10:21 am
    Hello
    Are there any possible solutions for this problem?
    Because it creates DMX and MIDI conflicts for me when both versions of Madmapper are open.
    I must first open version 3.7 so that it recognizes the blackmagic card to bridge via SPOUT to version 4.2 but it also takes the ENTTEC USB DMX box and also the midi controllers in preferences.
    The incoming HDMI signal comes from an EYESY which sends 720p60.
    noirtartare.fr
    garexp.org
