import/export masks as SVG/DXF
  • schack
    by schack » Thu Oct 28, 2021 2:09 pm
    One thing I would really wish for is the ability to import/export masks as SVG/DXF. It seems like a no-brainer feature and it surprises that its not available already.
    Re: import/export masks as SVG/DXF
    by franz » Fri Oct 29, 2021 11:52 am
    quick workqround, you can import a SVG as lines, then if the shape is closed, select the lines you need, and copy paste them in a quad surface ' mask.
