Fx not fading between 2 cues from same surface
  • alex.stars
    by alex.stars » Sat Oct 30, 2021 8:27 pm
    Hi, I am creating different cues from a same surface each containing a different fx and media. The problem is the fading does not occurred anymore when there is a change of effect. When effect is off it works normally.
    I found a way to make it work by duplicating the surface and having only one of the opacity at a time for each cue.
    I am wondering if there is a more simple way to do it? Or maybe it is not possible because the way the effect module works?
Users browsing this forum: No registered users and 69 guests
