What is the COMP variable in a fixture custom expression
  • jokecr
    by jokecr » Sat Oct 30, 2021 11:24 pm
    Here is what I have worked out regarding the use of expressions in fixture definitions. Can't work out what COMP represents.
    Component types:
    • R: red (R)
    • G: green (G)
    • L: luminance ((0.299 * R) + (0.587 * G) + (0.114 * B))
    • W: white (min(R, min(G, B)))
    • B: blue (B)
    • C: cyan (1 - R)
    • M: magenta (1 - G)
    • Y: yellow (1 - B)
    • Expression: Any GLSL equation with a float result
    In addition to R, G, B, L, W, C, M, Y expressions have these variables available:
    • (slider name): The value of any slider in your fixture
    • INDEX: Pixel index in a multi pixel fixture
    • posX: Column index in a multi pixel fixture
    • posY: Row index in a multi pixel fixture
    • COMP: What is this? It appears to be a value of 2048 in my current setup
    • time: time in microseconds
    Re: What is the COMP variable in a fixture custom expression
    by mad-matt » Mon Nov 01, 2021 12:10 am
    COM is the index of the channel being processed inside the pixel. For instance for a RGB (8 bits per component), COMP will be = 0 for R channel, 1 for G channel, 2 for B channel.
