How to map in MM, make a movie, project?
  • JJHP3
    by JJHP3 » Wed Nov 03, 2021 1:57 am
    I've been trying to map onto a surface, use Syphon Recorder to record and then put clip on an SD card into a Micca Speck into a projector. Never quite lines up... seems a resolution problem between all 3 components? I've read as much as possible about this and still have no pathway to success. My projector in MM is set to the same as the native resolution of the projector, as is Syphon. Huh. Stumped. Ideas??
    Thanks, John
  • Saavik8
    Re: How to map in MM, make a movie, project?
    by Saavik8 » Sat Nov 06, 2021 7:54 am
    What are the specs of your projector, micca & output in MM? Have you tried seeing how something unmapped transfers over between the computer and the micca (ie a test pattern jpg without any mapping adjustments)
