mapping, LED and multichannel audio set up
  • neleff
    by neleff » Mon Nov 08, 2021 2:34 pm
    Hi!
    I'm having a videomapping on a building, and in that building there is a LED installation.
    First plays the mapping, then the LEDs. They have both a sound system, but it will be played from 1 pc. I have an external sound card.
    How to set up?
    Can I address the soundchannels in madmapper?
    Or should i make the mapping video with 4 channel and only audio on 1-2 and the LED-video also 4 channel with only audio on 3-4?
    Also, for smoothest playback: should i export everything in HAP? (also the video for the LEDs?)
    thx
    Re: mapping, LED and multichannel audio set up
    by mad-matt » Mon Nov 08, 2021 6:04 pm
    The easiest would be to make a single movie with, on the left, the part for video, and on the right the part of LEDs. And all audio channels in the same movie. Then you don't have synchronization to handle.
    For multi channel output (more than stereo) you need to use ASIO output type (in preferences / audio) so you need an audio card with ASIO support (or use ASIO4ALL)
Users browsing this forum: Baidu [Spider] and 57 guests
