Performance: HAP vs GIF
  • looseopinions
    by looseopinions » Sat Nov 13, 2021 3:43 pm
    Hi, I am putting together a show in MM that will have a large number of animated GIFs.
    From a size standpoint, converting GIFs to HAP result in a much larger file size, and from a convenience standpoint I can't preview HAP in Finder which is a pain.
    How does GIF compare to HAP performance-wise? I'd prefer to keep my files as GIF unless there is a major performance gain by converting to HAP.
    Re: Performance: HAP vs GIF
    by mad-matt » Tue Nov 16, 2021 12:49 am
    HAP is great for very high resolution. I'm not used to see GIFs in user projects but if it works for you why not. Best is to try. i would say: test using twice more visuals than what you might do in your show and if it works, don't loose time recompressing.
Users browsing this forum: Baidu [Spider] and 53 guests
