Advice for Projection Outputs (6ea)
  • LightSmiths
    by LightSmiths » Wed Dec 08, 2021 9:52 am
    Hello, I'm new to MadMapper and the forum. We're doing a proof of concept study for projection mapping a dome where we'd need 6 projectors, therefore 6 HDMI outputs. Can anyone please advise on best practices for presenting the outputs to MadMapper? Something like a couple of Datapath Fx4 units linked together?
    We're using it on a brand new Macbook pro 16" with 2TB HDD, 32GB shared memory, and M1 processor.
    Our content plan is to use just one 1920x1080-30fps stream of content mapped across all of the projectors. Essentially we will use the 6 projectors to slice up the single frame of content and map it over the dome.
    Thank you all in advance for any replies.
  • ogbadboi
    Re: Advice for Projection Outputs (6ea)
    by ogbadboi » Wed Dec 08, 2021 8:30 pm
    Hey I'm in a similar boat, looking for how to get multiple outputs to 6+ projectors. My setup is using a desktop computer though.
    I did find this bit of info over at resolume, which isn't an exact answer but it's better than nothing; I'll be lurking here to see what others come up with.
    https://resolume.com/support/en/lots-of-outputs
  • LightSmiths
    by LightSmiths » Wed Dec 08, 2021 11:42 pm
    Great article, thanks for sharing!
    by mad-matt » Thu Dec 09, 2021 5:03 pm
    Datapath FX 4 is great. We tested up to 4 (so 16 screens) on a nVidia 1080 (not even Ti) without problem, so 16 fullHD 60. A 6 years old computer => https://www.youtube.com/watch?v=jwUdfu5LsiU
  • LightSmiths
    by LightSmiths » Thu Dec 09, 2021 6:02 pm
    Thanks Mad Matt!
  • LightSmiths
    by LightSmiths » Thu Dec 09, 2021 6:03 pm
    Here's Garage Cube's Support Response:
    Hi LightSmiths,
    According to Apple, the MacBook Pro (16-inch, 2021) specs are :
    Simultaneously supports full native resolution on the built-in display at 1 billion colors and:
    Up to two external displays with up to 6K resolution at 60Hz at over a billion colors (M1 Pro) or
    Up to three external displays with up to 6K resolution and one external display with up to 4K resolution at 60Hz at over a billion colors (M1 Max)
    So you could use two datapath FX4 or equivalent and get 8 outputs.
    Best regards,
