nasty : cant read avi files
  • mattblack
    by mattblack » Fri Jun 06, 2008 11:53 pm
    hi there
    new to the mac, from pc. my avi files will not load. they play in qt. on my friends mac, same os (jag latest) and same qt and same modul8, they WILL play. nasty!
    heres an example flle; error i get is 'media not supported'
    http://download.yousendit.com/A5B3F8C43F321059
    thanks. my clip lib is in that format so i need to sort it.
    x
    matt
  • Lupin
    by Lupin » Sat Jun 07, 2008 10:34 am
    read the manual…
    from the beginning modul8 can only play quicktime movies or stills or quartz composer patches.
    anyway even if you want to play your loops on any OS you should use photojpeg quicktime files cf. resolume spec sheet or arakaos spec sheet.
  • mattblack
    by mattblack » Sun Jun 08, 2008 1:24 am
    read my post: the question is why can my mates mac machine load the avi files OK but my identical machine not?
    can you play them?
    you said:
    read the manual…
    on the pc, i use vjamm and ffrender. they only load avi not qt. so it was not possible to make a clip lib in qt, seen?
    thanks
    by sigmasix » Sun Jun 08, 2008 9:32 am
    check the different codecs you have on your different macs. The avi files are containers like mov files, then inside your video is compressed using a specific codec, check if you have it
  • mattblack
    by mattblack » Sun Jun 08, 2008 8:59 pm
    thanks sigma...my lib/qt folder is the same as my mates; is there anywhere else i should look?
    x
    m
    by sigmasix » Sun Jun 08, 2008 9:23 pm
    try to install Perian, maybe it can help
    david
    by david » Mon Jun 09, 2008 1:53 pm
    Hello Matt,
    x
    m
    If Quicktime player loads the AVI file then Modul8 should also be able to play it (at least version 2.5.5).
    Mattblack, which version of Modul8 are you using ?
    Best regards.
    David.
  • mattblack
    by mattblack » Mon Jun 09, 2008 3:31 pm
    downloaded 2.5.5, still wont load avi whilst qt will!
    thanks
    x
    m
    by sigmasix » Mon Jun 09, 2008 5:04 pm
    I think there need to be clarifications
    1: on one machine you can play your avi file in both quicktime AND modul8?
    2: on the other one you can read your avi file in quicktime but not in modul8?!?
    or in point 2 you cannot read your file in quicktime and modul8?
  • mattblack
    by mattblack » Thu Jun 12, 2008 3:34 pm
    2: on the other one you can play your avi file in quicktime but not in modul8?!?
    That is correct!
    x
    Matt
    wygiwys
    by wygiwys » Fri Jun 13, 2008 3:09 pm
    Maybe they have flip4mac installed?
    This lets avi files play in qt
    What You Get Is What You See
    WYGIWYS.tv
  • mattblack
    by mattblack » Fri Jun 13, 2008 3:45 pm
    i also have flip installed.
  • queglay
    by queglay » Thu Aug 14, 2008 9:43 am
    im having this problem as well actually. i can play avi files in qt, but not in modul8.
  • mattblack
    by mattblack » Sat Aug 23, 2008 10:19 pm
    yes mate.
    converting everything is an option, but it would be wicked if modul8 could properly help escapees from Windows!my lib is like 2terabytes...
    x
    M
