multitrack audio interface with the minimad
  • JimTurner
    by JimTurner » Tue Jan 04, 2022 12:50 pm
    Hi we have a project at present which will include 16 tracks of audio synced with dmx light. I understand now that the minimad can handle multitrack audio. It would be great to have the whole show being run by minimad if possible...
    So far in our prototypes we have been using the cymatic lp16 as and audio interface. Can mini mad comunicate with this unit do you know? If not can you suggest a compatible audio interface...
    Re: multitrack audio interface with the minimad
    by Pierre Guilluy » Tue Jan 04, 2022 2:38 pm
    From what I read on the product's description, it's iOS compatible, meaning it's system compliant and shouldn't require any specific drivers, so it should work on the MiniMad.
    So far we've tested with up to 8 audio tracks using a ESI GigaPort HD+: https://www.esi-audio.com/products/gigaporthd+/
    We've never tested with 16 audio tracks and tens of DMX universes at the same time, so it's difficult to guaranty the result, but we'll try assisting you as much as we can.
    Let us know!
  • JimTurner
    by JimTurner » Mon Jan 10, 2022 3:27 pm
    Thank you Pierre, that sounds promising.. I will let you know how we get on :)
