Problem to create in a kind of "Playlist" of video to map on Led
  • jobeejoba
    by jobeejoba » Mon Jan 10, 2022 2:36 am
    I look for the best way to have a kind "Playlist" of videos that could map on LED by MM in the same file.
    I have in mind a kind of playlist like on music or video player.
    I tried to add some video in different "scenes" in the Module Tab. Also I have this kind of Playlist. However, I feel like the video are mapped less smooth, it's like the machine is more solicited. I have 12 videos of 30 MB (not so much finally...).
    Is that right?
    And the main issue is that I can't play the sound when the videos are played from a scene. If I play it directly in the Light fixture creation tab I can hear the sound. Also I'm sure the sound is enabled. But if I play it from Module Tab mode, I can't hear anything.
    Could you please help me?
    Best regards
    Re: Problem to create in a kind of "Playlist" of video to map on Led
    by mad-matt » Tue Jan 11, 2022 11:08 am
    You have to enable audio playback on your movies before creating the scenes (or update the "Audio Enabled" parameter in your scenes, refer to documentation in menu Help / MadMapper User Guides / Scennes & Cues.
    I don't understand, the module tab has nothing to do with videos.
