IMPORT SVG LINES TO USE AS MASK - Madmapper 5.0.4
  • MediaCraft
    by MediaCraft » Wed Feb 02, 2022 12:02 am
    I'm trying to do the most basic videomapping thing.
    I have my building vector mask made in Illustrator as a vector file.
    I export my mask from the illustrator as SVG - the size and ratio are OK I checked.
    I import the SVG file to MadMapper and use it as LINES - looks good.
    Now the problem I have is that I want to be able to use my SVG shapes as a MASKS for the new quads I create in madmapper.
    However when I CMD-C CMD-V (copy - paste the LINES) from the LINES surface to the MASK section in the new QUAD surface - the size of the newly created MASK NEVER MATCHES THE ORIGINAL INPUT.
    I have checked the input size of quad - I always try to match it with the original file.
    My projection orientation is portrait 1200px x 1920px.
    SO my question is: Is it possible to do something which is possible in ANY other software - to import SVG LINES and use them as MASKS in MadMapper without trying to match them manually?
    I would greatly appreciate your help.
    Kind Regards
    Aramaki
    Re: IMPORT SVG LINES TO USE AS MASK - Madmapper 5.0.4
    by mad-matt » Fri Feb 04, 2022 11:03 am
    We solved this issue. Will be in 5.1. I PM a pre-version.
    Thanks for reporting
  • MediaCraft
    by MediaCraft » Tue Feb 08, 2022 10:59 pm
    Again - thanks for sending me the working version - right on time before the production deadline!
