MadMapper 5.0.5 is released
    by MADben » Fri Feb 04, 2022 11:43 am
    Dear mappers,
    We just released the 5.0.5 update which comes with many fixes and the support for Playstation 5 controller,
    The update is free for v5 owners and available on the MadMapper website / user account / Downloads
    MM 5.0.5 Release Notes
    ADDITIONS
    + Added support for Playstation 5 Controller
    IMPROVEMENTS
    * Quit fullscreen when opening a MiniMad export dialog to avoid being stuck if the display got disconnected
    * Updated MiniMad user-guide
    FIXES
    - Fixed possible fullscreen issue appearing on the wrong screen (macOS)
    - Fixed video-output resolution not corresponding to the display's resolution (macOS)
    - Fixed authorisation failing with error 400 (Windows)
    - Fixed login using some emails with long domain extensions
    - Fixed Library not showing the right resource type at startup
    - Fixed Laser-Output being listed in Export Vide Mapping to MiniMad
    - MiniMad Light: Fixed audio playback using the mini-jack
    - Fixed generating video lines from DMX Fixture Circle
    - Fixed possible issue when dragging controls to reorder them
    - Fixed possible issues cueing Global BPM or Cue Scheduler
    Enjoy!
    The MAD Team.
  • jasonbeyers
    Re: MadMapper 5.0.5 is released
    by jasonbeyers » Sat Feb 05, 2022 6:18 am
    Thanks Garagecube team!
    Unfortunately I'm getting "Access Denied" errors when trying to download 5.0.5 from madmapper.com. It's only an issue with that link, the other builds are still downloadable for me (from the same authenticated session on website).
    by MADben » Tue Feb 08, 2022 1:34 pm
    Hi Jason, thanks for reporting, it's fixed now
Users browsing this forum: No registered users and 53 guests
