Error 0xc000007b at launch MM 3,4 & 5
  • KaOsphere
    by KaOsphere » Fri Feb 18, 2022 1:52 am
    Hello all,
    after a year off, I reinstalled my madmapper and I'm not able to lauch the program. I get :
    The application failed to initialize and will now terminate (Error 0xc000007b).
    I tried to reinstall, cg drivers, vcredist, dx...to no avalailiable...
    MM5 works on my old laptop though...
    Anyone got an idea ?
    Thanks a lot.
    Re: Error 0xc000007b at launch MM 3,4 & 5
    by mad-matt » Fri Feb 18, 2022 4:37 pm
    That's not a known issue.
    Please send a mail to support[at]garagecube(dot)com with:
    - log file, located in
    C:\Users\your_login\AppData\Roaming\Garagecube\MadMapper\Logs
    you can type this in file explorer address bar:
    %AppData%\Roaming\Garagecube\MadMapper\Logs\
    - crash dump if any:
    C:\Users\your_login\AppData\Roaming\Garagecube\MadMapper\.CrashDumps\
    %AppData%\Roaming\Garagecube\MadMapper\.CrashDumps\
    We'll find out.
    Thanks
    by mad-matt » Fri Feb 18, 2022 5:20 pm
    Please also try to execute manually the file "VC_redist.x64.exe" available in C:\Program Files\MadMapper 5.0.5
    You can also try to uninstall VC redistributables from Windows / "Add or Remove Programs" and then reinstall it.
  • KaOsphere
    by KaOsphere » Mon Feb 21, 2022 11:24 am
    Hi Matt, thanks for your reply...I tried to uninstall all c++ libraries end to reinstall manually and nothing changed.
    I don't have any of the folder you mention created on my harddrive. ( installations are ran as administrator and folder has R/W permission )
    Problem persists...Intereting to mention that I have the exact same problem with Notch.
    3dsmax, houdini, vray, touch designer, all adobe works as normally expected though...
  • KaOsphere
    by KaOsphere » Wed Mar 16, 2022 11:33 am
    Just an update if that can be of some help.
    Windows Uac was causing the issue, after deactivating it completely, everything installed and ran fine.
    Kudos to Notch support for helping me troubleshoot this.
  • marcellm
    by marcellm » Wed Aug 17, 2022 6:15 pm
    Thank You so much for this post. Windows UAC caused MM 5.1.5 to now load on my Windows 11 machine, which I updated to latest OS including other software for Alienware M17. I though that is what screwed me; turns out, disabling User Account Control fixed the issue. So I didn't lose 2 days of work after all. Thanks You so much!
    Marcell
    by mad-matt » Mon Sep 05, 2022 3:58 pm
    We couldn't reproduce this issue but we're investigating. Do you know if you were using an admin user account when the issue happened ?
