Video projection on sphere /globe
  • neils
    by neils » Mon Feb 21, 2022 5:14 pm
    I am trying to project onto a real sphere / ballon (approx. 1m diameter).
    To do this, I have loaded a 3D sphere as an object in MadMapper. Instead of compensating for the perspective distortions that result from the curvature/bending, the distortion is increased.
    The distortion fits on the monitor, but not on the real projection. Here the distortion should actually be negative.
    What is my mistake?
    What do I have to adjust and how?
    Thank you very much for your support.
    Greetings
    Nils
  • timbrass
    Re: Video projection on sphere /globe
    by timbrass » Mon Feb 28, 2022 12:30 pm
    Have you got a picture? Would you not need to create a 3D "cup" (inside of a sphere) and pretend to project onto that?
  • neils
    by neils » Sun Mar 20, 2022 9:42 am
    Thank you for the answer.
    It didn't work with a "cup" either. I now use a "normal" flat projection on the balloon. I accept the distortions and they are not as strong as I thought.
