Full screen issues on 5.0.6
  • MisterVJ
    by MisterVJ » Tue Mar 01, 2022 1:04 am
    MM Build 5.0.6 on M1 macpro
    Just updated to .0.6 but when i tested, had issues when selecting the video output destination. every time i tried to select the proper output device and went to full screen, output went full screen on interface screen only.
    Tried restart MM / nope
    tried hot swap monitor connections / nope
    restart computer / nope
    Roll back to 5.0.4 Problem solved
    p.s.
    Any known workarounds to solve the orange camera status indicator led issue on the output screen /top right on new mac OS?
    Able to remove the facetime camera from the input sources (when not needed) might fix it?
    Re: Full screen issues on 5.0.6
    by mad-matt » Mon Mar 07, 2022 12:39 pm
    The 5.0.6 fullscreen / M1 Max issue is weird. do you maximize user interface (MadMapper window)
    There's a github with a tool for removing it. In Madmapper 5.1 (beta out this week) you'll be able to disable audio input, so it should disappear in this case. we're in touch with Apple about this issue but things seem to be slow there...
