Reset Perspective
  • blaus_binski
    Reset Perspective
    by blaus_binski » Wed Mar 09, 2022 1:40 pm
    Hi there
    If I have a 16:9 Video I would like to project on a 16:10 projector with a Letterbox, so that the original file doesn‘t get squeezed. What should I do?
    In the Input I can select „Entire Media“ to not "select" only the default square.
    Is there anything similar in the output?
    The only thing reasonable to me would be the „reset perspective“ button, but hitting that, makes the output squeeze to said default square.
    Is there a setting, where I can set the "default" Aspect Ratio to "Source" instead of 1:1
    Can anybody help?
Users browsing this forum: No registered users and 58 guests
