Monterey (ios12.2.1, intel) - MM5 Crashed?
  • vision7yk
    by vision7yk » Sat Mar 19, 2022 7:45 pm
    I downloaded the MM5 while upgrading to the MacBook Monterey ios this time. I set up all the scenes for the performance and tried to save the file. While I pressed the save button, suddenly it crashed, and all the scenes were disappeared. :evil: :evil: :evil: :evil: And It is kept showing 'Project file is incomplete.' :shock: It makes me mad!!! I do not understand the problem and how I can fix it. :'( Does it any issue using MM5 at Monterey? Shouldn't I upgrade MM5 or Monterey? Should I have to downgrade the ios? My computer spec is MacBook Pro, GHz intel Core i9, 16GB 2400 MHz DDR4
    Re: Monterey (ios12.2.1, intel) - MM5 Crashed?
    by mad-matt » Mon Mar 28, 2022 9:32 pm
    No you shouldn't downgrade anything. I'm not aware of an issue that could make the application crash while saving. Did you send a crash report ? If so, did you set a email or do you know at which time you sent the report ? We can investigate.
