Mad Mapper will not open / MacOS Monterey 12.3.1
  • neils
    by neils » Fri Apr 08, 2022 4:55 pm
    I hope you can help me:
    After updating to MacOS Monterey 12.3.1 yesterday (previously Monterey 12.x), my MadMapper 3.7.11 no longer starts.
    A reinstallation does nothing. MadMapper 3.0 does not start either.
    Module8 in the current version also crashed on start-up. A new installation helped here.
    Is there a known conflict? Does an old file in the system have to be deleted?
    I am currently working on a video stage design for a theatre play.
    Thanks for the good support.
    Many greetings
    Nils
  • slidenspin
    Re: Mad Mapper will not open / MacOS Monterey 12.3.1
    by slidenspin » Mon Apr 11, 2022 5:03 am
    I am also having the same issue. The crash report mentions something about Python 2.7 not supported in the new Mac iOS.
    Hope we can get this fixed soon, as people's jobs depend on using this software.
  • neils
    by neils » Tue Apr 12, 2022 7:26 am
    Thank you for the answer.
    Do you have an idea for a workaround?
    The rehearsals start in a week and I only have my MacBook. Is there a way to downgrade without having to reinstall everything (applications, etc.)?
    Thanks and greets
    Nils
  • neils
    by neils » Tue Apr 19, 2022 8:49 am
    I did some research and found a solution:
    MadMapper must be updated to the latest version 5. This should make it work again.
