MadMapper (3.7.11) crashes - iOS 12.3. Python 2.7
  • slidenspin
    by slidenspin » Mon Apr 11, 2022 12:06 am
    MadMapper (3.7.11) crashes immediately after launching application. Tried older and newer versions of MM with same result.
    Crash report below mentions something about Python 2.7 not supported in iOS 12.3.
    Can't use the program at all until this is fixed.
    Process: MadMapper [1502]
    Path: /Applications/MadMapper 3.7.11.app/Contents/MacOS/MadMapper
    Identifier: com.garagecube.MadMapper
    Version: 3.7.11 (3.7.11.21072110086)
    Code Type: X86-64 (Native)
    Parent Process: launchd [1]
    User ID: 501
    Date/Time: 2022-04-10 14:54:28.7239 -0700
    OS Version: macOS 12.3.1 (21E258)
    Report Version: 12
    Bridge OS Version: 6.4 (19P4243)
    Anonymous UUID: DAFD3283-5514-74C3-1D15-7CCB3E848904
    Time Awake Since Boot: 1800 seconds
    System Integrity Protection: enabled
    Crashed Thread: 0
    Exception Type: EXC_CRASH (SIGABRT)
    Exception Codes: 0x0000000000000000, 0x0000000000000000
    Exception Note: EXC_CORPSE_NOTIFY
    Termination Reason: Namespace DYLD, Code 1 Library missing
    Library not loaded: /System/Library/Frameworks/Python.framework/Versions/2.7/Python
    Referenced from: /Applications/MadMapper 3.7.11.app/Contents/MacOS/MadMapper
    Reason: tried: '/System/Library/Frameworks/Python.framework/Versions/2.7/Python' (no such file)
    (terminated at launch; ignore backtrace)
    Application Specific Information:
    Thread 0 Crashed:
    0 dyld 0x10f4500de __abort_with_payload + 10
    1 dyld 0x10f466212 abort_with_payload_wrapper_internal + 80
    2 dyld 0x10f466244 abort_with_payload + 9
    3 dyld 0x10f41476f dyld4::halt(char const*) + 375
    4 dyld 0x10f4105a5 dyld4::prepare(dyld4::APIs&, dyld3::MachOAnalyzer const*) + 3995
    5 dyld 0x10f40f4d4 start + 388
    Thread 0 crashed with X86 Thread State (64-bit):
    rax: 0x0000000002000209 rbx: 0x0000000000000000 rcx: 0x00007ff7b7458608 rdx: 0x00007ff7b7458a70
    rdi: 0x0000000000000006 rsi: 0x0000000000000001 rbp: 0x00007ff7b7458650 rsp: 0x00007ff7b7458608
    r8: 0x00007ff7b7458670 r9: 0x0000000000000000 r10: 0x0000000000000090 r11: 0x0000000000000246
    r12: 0x0000000000000090 r13: 0x00007ff7b7458a70 r14: 0x0000000000000001 r15: 0x0000000000000006
    rip: 0x000000010f4500de rfl: 0x0000000000000246 cr2: 0x000000010f416e74
    Logical CPU: 0
    Error Code: 0x02000209
    Trap Number: 133
    Binary Images:
    0x10f40a000 - 0x10f475fff dyld (*) <dd9e80de-fb3b-349b-96a4-46874ad34d11> /usr/lib/dyld
    External Modification Summary:
    Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    Calls made by all processes on this machine:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    VM Region Summary:
    ReadOnly portion of Libraries: Total=31.9M resident=0K(0%) swapped_out_or_unallocated=31.9M(100%)
    Writable regions: Total=10.5M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=10.5M(100%)
    VIRTUAL REGION
    REGION TYPE SIZE COUNT (non-coalesced)
    STACK GUARD 56.0M 1
    Stack 8192K 1
    VM_ALLOCATE 12K 3
    __DATA 3136K 3
    __DATA_CONST 80K 1
    __LINKEDIT 1136K 4
    __TEXT 30.8M 2
    dyld private memory 1024K 1
    TOTAL 100.1M 16
    Full Report
    {"app_name":"MadMapper","timestamp":"2022-04-10 14:54:28.00 -0700","app_version":"3.7.11","slice_uuid":"448af2e7-34fb-34e3-b452-f443bfa74bb3","build_version":"3.7.11.21072110086","platform":1,"bundleID":"com.garagecube.MadMapper","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 12.3.1 (21E258)","incident_id":"72FA9768-6112-4334-B410-F172CF4E623D","name":"MadMapper"}
    "uptime" : 1800,
    "procLaunch" : "2022-04-10 14:54:28.6966 -0700",
    "procRole" : "Default",
    "version" : 2,
    "userID" : 501,
    "deployVersion" : 210,
    "modelCode" : "MacBookPro16,1",
    "procStartAbsTime" : 1838150169206,
    "coalitionID" : 1112,
    "osVersion" : {
    "train" : "macOS 12.3.1",
    "build" : "21E258",
    "releaseType" : "User"
    "captureTime" : "2022-04-10 14:54:28.7239 -0700",
    "incident" : "72FA9768-6112-4334-B410-F172CF4E623D",
    "bug_type" : "309",
    "pid" : 1502,
    "procExitAbsTime" : 1838177267751,
    "cpuType" : "X86-64",
    "procName" : "MadMapper",
    "procPath" : "\/Applications\/MadMapper 3.7.11.app\/Contents\/MacOS\/MadMapper",
    "bundleInfo" : {"CFBundleShortVersionString":"3.7.11","CFBundleVersion":"3.7.11.21072110086","CFBundleIdentifier":"com.garagecube.MadMapper"},
    "storeInfo" : {"deviceIdentifierForVendor":"68B1915D-ADF0-573A-837A-A28124E04200","thirdParty":true},
    "parentProc" : "launchd",
    "parentPid" : 1,
    "coalitionName" : "com.garagecube.MadMapper",
    "crashReporterKey" : "DAFD3283-5514-74C3-1D15-7CCB3E848904",
    "bridgeVersion" : {"build":"19P4243","train":"6.4"},
    "sip" : "enabled",
    "isCorpse" : 1,
    "exception" : {"codes":"0x0000000000000000, 0x0000000000000000","rawCodes":[0,0],"type":"EXC_CRASH","signal":"SIGABRT"},
    "termination" : {"code":1,"flags":518,"namespace":"DYLD","indicator":"Library missing","details":["(terminated at launch; ignore backtrace)"],"reasons":["Library not loaded: \/System\/Library\/Frameworks\/Python.framework\/Versions\/2.7\/Python","Referenced from: \/Applications\/MadMapper 3.7.11.app\/Contents\/MacOS\/MadMapper","Reason: tried: '\/System\/Library\/Frameworks\/Python.framework\/Versions\/2.7\/Python' (no such file)"]},
    "asi" : {"dyld":["Library not loaded: \/System\/Library\/Frameworks\/Python.framework\/Versions\/2.7\/Python","Referenced from: \/Applications\/MadMapper 3.7.11.app\/Contents\/MacOS\/MadMapper","Reason: tried: '\/System\/Library\/Frameworks\/Python.framework\/Versions\/2.7\/Python' (no such file)"]},
    "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
    "faultingThread" : 0,
    "threads" : [{"triggered":true,"id":29688,"threadState":{"r13":{"value":140701908437616},"rax":{"value":33554953},"rflags":{"value":582},"cpu":{"value":0},"r14":{"value":1},"rsi":{"value":1},"r8":{"value":140701908436592},"cr2":{"value":4550913652},"rdx":{"value":140701908437616},"r10":{"value":144},"r9":{"value":0},"r15":{"value":6},"rbx":{"value":0},"trap":{"value":133},"err":{"value":33554953},"r11":{"value":582},"rip":{"value":4551147742,"matchesCrashFrame":1},"rbp":{"value":140701908436560},"rsp":{"value":140701908436488},"r12":{"value":144},"rcx":{"value":140701908436488},"flavor":"x86_THREAD_STATE","rdi":{"value":6}},"frames":[{"imageOffset":286942,"symbol":"__abort_with_payload","symbolLocation":10,"imageIndex":0},{"imageOffset":377362,"symbol":"abort_with_payload_wrapper_internal","symbolLocation":80,"imageIndex":0},{"imageOffset":377412,"symbol":"abort_with_payload","symbolLocation":9,"imageIndex":0},{"imageOffset":42863,"symbol":"dyld4::halt(char const*)","symbolLocation":375,"imageIndex":0},{"imageOffset":26021,"symbol":"dyld4::prepare(dyld4::APIs&, dyld3::MachOAnalyzer const*)","symbolLocation":3995,"imageIndex":0},{"imageOffset":21716,"symbol":"start","symbolLocation":388,"imageIndex":0}]}],
    "usedImages" : [
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4550860800,
    "size" : 442368,
    "uuid" : "dd9e80de-fb3b-349b-96a4-46874ad34d11",
    "path" : "\/usr\/lib\/dyld",
    "name" : "dyld"
    "sharedCache" : {
    "base" : 140703575048192,
    "size" : 15224815616,
    "uuid" : "6cc5ecdc-5119-37f0-9a85-4f48a50f5f78"
    "vmSummary" : "ReadOnly portion of Libraries: Total=31.9M resident=0K(0%) swapped_out_or_unallocated=31.9M(100%)\nWritable regions: Total=10.5M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=10.5M(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nSTACK GUARD 56.0M 1 \nStack 8192K 1 \nVM_ALLOCATE 12K 3 \n__DATA 3136K 3 \n__DATA_CONST 80K 1 \n__LINKEDIT 1136K 4 \n__TEXT 30.8M 2 \ndyld private memory 1024K 1 \n=========== ======= ======= \nTOTAL 100.1M 16 \n",
    "legacyInfo" : {
    "threadTriggered" : {
    "trialInfo" : {
    "rollouts" : [
    "rolloutId" : "60da5e84ab0ca017dace9abf",
    "factorPackIds" : {
    "deploymentId" : 240000008
    "rolloutId" : "6112e14f37f5d11121dcd519",
    "factorPackIds" : {
    "SIRI_TEXT_TO_SPEECH" : "624b784416a70b047e45d9a6"
    "deploymentId" : 240000084
    "experiments" : [
    Model: MacBookPro16,1, BootROM 1731.100.130.0.0 (iBridge: 19.16.14243.0.0,0), 8 processors, 8-Core Intel Core i9, 2.4 GHz, 32 GB, SMC
    Graphics: Intel UHD Graphics 630, Intel UHD Graphics 630, Built-In
    Graphics: AMD Radeon Pro 5500M, AMD Radeon Pro 5500M, PCIe, 8 GB
    Display: Color LCD, 3072 x 1920 Retina, Main, MirrorOff, Online
    Display: NOVA HD CARD, 1920 x 1080 (1080p FHD - Full High Definition), MirrorOff, Online
    Memory Module: BANK 0/ChannelA-DIMM0, 16 GB, DDR4, 2667 MHz, SK Hynix, HMAA2GS6CMR8K-VK
    Memory Module: BANK 2/ChannelB-DIMM0, 16 GB, DDR4, 2667 MHz, SK Hynix, HMAA2GS6CMR8K-VK
    AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x7BF), wl0: Jul 12 2021 18:02:56 version 9.30.464.0.32.5.76 FWID 01-c081cfed
    Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
    Network Service: Wi-Fi, AirPort, en0
    Network Service: iPhone, Ethernet, en6
    USB Device: USB31Bus
    USB Device: iPhone
    USB Device: USB2.0 Hub
    USB Device: FHD Webcamera
    USB Device: USB 2.0 BILLBOARD
    USB Device: T2Bus
    USB Device: composite_device
    USB Device: Touch Bar Backlight
    USB Device: Touch Bar Display
    USB Device: Apple Internal Keyboard / Trackpad
    USB Device: Headset
    USB Device: Ambient Light Sensor
    USB Device: FaceTime HD Camera (Built-in)
    USB Device: Apple T2 Controller
    Thunderbolt Bus: MacBook Pro, Apple Inc., 63.5
    Re: MadMapper (3.7.11) crashes - iOS 12.3. Python 2.7
    by Pierre Guilluy » Mon Apr 11, 2022 10:30 am
    Apple did entirely remove Python from the system starting with macOS 12.3.
    We advice you upgrade your license and download the latest MadMapper 5.0.7 which is compatible with macOS 12.3.
    Otherwise you can also install a previous version of macOS on a separate drive to run MadMapper 3.
