LED Controller glitching out
  • christianhaggerty
    by christianhaggerty » Fri May 13, 2022 7:01 am
    I'm having this weird issue all of a sudden.
    I'm using madmapper for LED lights.
    When I try to put the LEDs to solid white it seems to reset the controller...
    It seems as though I can do solid red, solid green, solid blue.. but if i get too much all at once it seems to glitch out the controller and reset. Could this be a power issue? I've checked all my connections, restarted the contoller, restarted my computer, started a new project in madmapper and made a set of led fixtures from scratch... still even when using some of the materials if i get too much illumination accross the fixtures all at once it seems to trip out and reset my controller... it's very annoying...
    any ideas?
    Re: LED Controller glitching out
    by franz » Fri May 20, 2022 4:52 pm
    sounds like a power issue. at full white you're drawing too much current for your setup
