50fps WIFI synced player 200m away from computer?
  • MediaCraft
    by MediaCraft » Fri May 13, 2022 2:00 pm
    I'm preparing an installation where I need to sync the projection mapping from 5 remote projectors located very far away from one another - like 200m away from the FOH base location.
    I need to project HD content in 50fps on each of them.
    As far as I know MiniMAD can only do 30fps and does not have WIFI synchronisation...
    Can You recommend some other solution?
    Best!
    Dariusz
    Re: 50fps WIFI synced player 200m away from computer?
    by Pierre Guilluy » Mon May 16, 2022 9:15 am
    If you want some HD content playing at 50fps, you would more likely use MadMapper than the MiniMad.
    MadMapper can output to multiple displays at the same time, but since it lacks in-between-computers synchronisation, you'll need to send your signal 200m away, using video extender solutions.
    Another solution may be using small computers as nodes that receive and display the NDI signal from the MadMapper.
    Anyways you'll need either long ethernet cables or a strong wifi network.
    Remember using wifi will add a little latency, and the signal may degrade if the place gets crowded.
