Context menu option to reset FX settings to defaults
  • jasonbeyers
    by jasonbeyers » Fri May 13, 2022 6:27 pm
    Right-clicking on a material (in the media bin) shows an option to reset parameters to their default values. This is really handy for reverting shader settings to a known state.
    Feature request: it would be great if we had a similar context-menu option for surface FX, to reset all the settings *of the currently selected FX for a surface* to their default values. Maybe when right-clicking on the FX name, when viewing surface details.
    At the moment, the only way to achieve this is to Cmd-click (mac) or Ctrl-click (windows) on every individual setting in the currently-selected FX. This can be very tedious, especially for FX with 20+ parameters.
    This would save people time, when working a lot with surface FX.
    Re: Context menu option to reset FX settings to defaults
    by franz » Fri May 20, 2022 4:50 pm
    +1
