Audiofile playing from Bank
  • augenblick
    by augenblick » Wed May 18, 2022 4:19 pm
    Hi
    We have an installation where we project to 6 cubes (18 surfaces).
    All layed out neatly with different bank that are looping and can be triggered from the keyboard or via a OSC touchpanel.
    Now the client wishes to play some continuous background music while the banks are running.
    How can this be done.
    Via audioplayer?
    But how would I trigger it at the start of a bank?
    There is no music on any of the clips that are played in any bank.
    Just 10-12 scenes in a loop.
    Thanks
    Re: Audiofile playing from Bank
    by Pierre Guilluy » Thu May 19, 2022 9:46 am
    If your audio-track is not related to any of your video, I would recommand using a AudioPlayer module.
    You can create a cue that will trigger both the first video and the audio.
    Then you can use the cue playback feature to change media every-time the current one finished, and optionally stop audio playback.
  • augenblick
    by augenblick » Mon May 23, 2022 5:32 pm
    Thanks
    I will give it a try.
  • augenblick
    by augenblick » Wed May 25, 2022 3:27 pm
    Worked. Thanks!
    I placed the audioplayer module into the 2nd Scene of any bank in the list, so audio starts playing as soon as Scene 2 starts.
    Scene 1 is black on each bank for 0.5 seconds and gives the audio player the cue to NOT play any audio so that all audio stops before a new bank is played via keyboard or OSC.
Users browsing this forum: No registered users and 60 guests
