Modul8 v.2.5.5 Released!
  • garageRoot
    by garageRoot » Mon Jun 16, 2008 9:33 pm
    We are pleased to announce the final release of Modul8 v.2.5.5!
    Big thanks to all those who participated in the beta testing phase. Your continued support and feedback is essential to the further development of modul8.
    Modul8 v.2.5.5 update is free for all registered users of modul8 and can be downloaded by using the 'Download modul8 update' command from the 'modul8' menu within the application. The command will launch your default web browser and then download a .zip file that will self extract to an .image file. Inside the image file you can drag and drop the application into your applications folder.
    If you want to use the modules you have downloaded or created using v.2.5.4 it will be necessary to move them for the modules folder of that version and put them in the modules folder of v.2.5.5.
    Listed here are numerous added features and fixes that come with this update.
    Features added:
    - You can now change the post colorization of a layer using swatches or a color picker.
    - In the transformer layer panel a knob has been added that allows for manipulating the field of view of a layer.
    - In the option tab of the main layer interface added a check box has been added that allows you to connect or disconnect the fading of audio with the opacity of the layer.
    - Added support for media created in Flash using the .swf format (which was dropped from Quicktime).
    - Changed the maximum size of multi-output windows to unlimited.
    - Added an option to reset the window locations in multi-output mode and the ability to save the positions of windows in multi-output mode.
    - Added a new module to trigger media by name.
    - Added new keywords on the module system :
    "info_media_names" (read only) Allows you to access the name of your media.
    "info_media_pathsAndNames" (read only) Allows you to access the file path of your media.
    "direct_media_change" (Write only) Load a new media in the the media set.
    "set_direct_layer_media_stepFrame" Increment a movie clips frame.
    Fixes:
    - Fixed module serialization in the project
    manager when the project is saved.
    - Fixed problem when a big movie file (i.e. a 1 gigabyte file) fails to preload.
    - Fixed sound disappearing when slowing down/fading out/in
    a movie.
    - Fixed a problem where module windows would drift from under the cursor
    when moved using a Wacom tablet.
    - Fixed a problem of incorrect resizing of the media window when rendering
    is heavily loaded.
    - Fixed Preview pane positions not being saved when entering/leaving full
    screen mode or advanced output mode.
    - Fixed a problem when using large image files.
    - Fixed a problems with multi-output mode (white images).
    - Fixed possible crashes and problems on with logical record rendering and playing system.
    - Fixed a possible crash with load/unload of movies when free memory is low.
    - Fixed a possible crash with big movie and large image file.
    - Fixed a possible crash problem on some keywords when a wrong value is
    used with the setValue on the Module system.
    - Fixed a problem of incorrect resizing of the media set window and info mode.
    - Fixed a problem with the module parameter serialization in project files.
    - Fixed problems with sound latency / stopping.
    - Fixed a problem with keyboard mapping and different languages in Mac OS X 10.5 Leopard.
    - Fixed a problem with midi mapping by position and toggle button.
    - Fixed a possible performance problem when hiding movies and changing the layer set.
    - Fixed a minor problem with modules windows drifting when moved with a Wacom tablet
    - Fixed a minor problem with resetting window locations when the preview ratio is not set to 4/3.
    - Fixed a minor problem with the master invert, add color and wide output ratio.
    If you have any troubles downloading the update please do not hesitate to contact 'support [at] garagecube.com' for assistance.
    Kind regards,
    The Modul8 Team
  • mowgli_uk
    by mowgli_uk » Tue Jun 17, 2008 12:16 pm
    Great news, thanks guys!
  • VJnutcracker
    by VJnutcracker » Tue Jun 17, 2008 8:12 pm
    Nice one guys.
    zoophar
    by zoophar » Wed Jun 18, 2008 12:05 pm
    Yes !!! Nice one !!!!
    Cheeeerz!!!!!
  • auspuff
    by auspuff » Wed Jun 18, 2008 1:12 pm
    nice one!
    What flash versions can I use? How is the flash playback done now that quicktime does not support it anymore?
    nesral
    by nesral » Wed Jun 18, 2008 10:02 pm
    thanks for this update !
    david
    by david » Fri Jun 20, 2008 8:11 am
    Hello auspuff,
    Modul8 is using the Flash plugin of Safari, so you could load any file that loads in Safari.
    Best regards.
  • oku
    Excellent!!
    by oku » Fri Jun 20, 2008 11:48 am
    omedetou!!
  • lamepantallas
    by lamepantallas » Sat Jun 21, 2008 7:01 pm
    Bueeenisismo!!
    Greaaat!
    Jesper Fryd
    by Jesper Fryd » Mon Jun 23, 2008 5:58 pm
    ERROR: CANNOT GET DOWNLOAD LINK
    Help :(
    Jesper Frydenlund
    Art Director | www.weare.dk
    by boris » Tue Jun 24, 2008 12:28 pm
    Help = email to the support
    :wink:
  • anomad
    by anomad » Thu Jun 26, 2008 4:04 am
    . fantastic! :D
    . very, very nice!
Users browsing this forum: Baidu [Spider] and 24 guests
