Output uses different GPU
  • techBys
    by techBys » Mon Jun 06, 2022 11:27 am
    Dear Community
    I'm using maddmapper with 8 projectors and dual Quadro A400 GPU Card
    i notice while I'm adding new output that it's using intel graphic, how i can change that ?
    Re: Output uses different GPU
    by mad-matt » Sun Jun 12, 2022 8:45 pm
    No it's not using Intel GPU, it's just showing to which GPU your display is attached.
    Because of OpenGL constraints on Windows, MadMapper will use the GPU attached to the display set as "Main Display" in Windows preferences.
