Unable to use Artnet over Ethernet and Wifi at same time.
  • ProjectileObjects
    by ProjectileObjects » Wed Jun 22, 2022 11:15 pm
    I'm unable to control artnet devices over ethernet and wifi at the same time (assuming the same with multiple ethernet USB adapters).
    From the Artnet drop down, I have to select a network (192.168.8.xxx) from there, my ethernet will poll the devices on the network. If I select wifi (192.168.1.xxx) it polls the devices on wifi and shows the connected ethernet devices (for a short while), then MM cuts off the Ethernet devices.
    If I poll the wifi devices first, then switch to ethernet, MM cuts off the wifi devices. If I manually add in the wifi IP addresses and routing information they do not work. They only seem to connect if I poll the device with the correct drop down.
    Is Madmapper able to run artnet communications across multiple network adapters? (in this case Ethernet & Wifi)?
    I can do this with VDMX, QLC+, and other lighting softwares.
    Thanks
